Posted by Billy NY on November 09, 2013 at 10:10:06 from (72.226.79.200):
In Reply to: 4in1 bucket vs Blade posted by ANOTHERBPULLER on November 08, 2013 at 17:28:11:
The difference is relatively simple, a 6 way blade, is best suited for fine grading, the 4 in one, is more utilitarian, pick, load, though when you open the bucket, you have essentially a dozer blade, you don't have tilt or angle, so its a lot more work, planning or what have you to start a sloped cut or grade something that is not flat, put a windrow on one side, get the machine tilted, say for ditching or what have you/ Way back when, this was the method, you can see much of this in the instructional portion of LeTourneau's dozer kits from the 40's and before. Though there was manual tilt and angle models others were straight push arms, and thats what you have with a 4 in one bucket, typically, as its on a set of loader arms. You can stump small trees with a grading tractor and 6 way blade, push same off to clear an area, ditch, grade, cut, or what have you. If you have a lot of material to move or load out, well the 4 in one may serve you better. Like has been mentioned a rubber tire backhoe, and this country is loaded with used ones, is also something to consider when figuring on 1 dedicated machine. Ideally, a backhoe with a 4 in one bucket, and backhoe bucket thumb is an extremely versatile machine to have, add a dozer with a 6 way blade, not much you can't do within the confines of each given size and power.
Realize that a 6 way blade is a nice feature, but if you have large rocks, trees or what have you, better to have a larger dozer with push arms on trunnions attached to the track frames, those will tolerate the heavy forces at work and are designed for same, unlike a 6 way. Small trees are fine, tilt, angle down, cut the roots, cut around them, and push over wont hurt a thing.
I was on a D6D Cat going back to '93 or so, and was pushing off large pieces of blast rock in a fill area, tilt cylinder bore had a some wear, and I found out how strong it was pushing from one side a little, this was a straight, push arm blade with only tilt, broke the bore and pulled the cylinder free. Lot of power to those tracks sometimes, equipment mechanic said it was due and saw from what we were doing, should have had the D8K in there.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
