Crawlers, Dozers, Loaders & Backhoes Discussion Board
trans case
Posted by mnoliverguy on November 08, 2013 at 17:57:25 from (68.235.72.39):
Is the trans case on a jd450b cast steel or cast Iron? I have been told both,if either what rod would you use to weld a cracked case?
Latest Ad: Super WD9. [More Ads]
