That sounds like the pump is not pumping oil to that side,slacken the hoses at the motor,spin the engine over on the starter while engaging the control for each direction,if there is no oil coming from the loose hoses the pump is not pumping,either the control valve is not moving the valve,the regulator valve is stuck open or the pump is not pumping,what was the trouble at first?.
Today's Featured Article - Restoration Story: 1964 JD 2010 Dsl - Part 2 - by Jim Nielsen. Despite having to disassemble the majority of my John Deere 2010's diesel engine, I was still hopeful I could leave the engine-complete with crankshaft and camshaft-in the tractor. This would make the whole engine rebuild job much easier-and much less expensive! I soon found however, that the #4 conrod bearing had disintegrated, taking with it chunks of the crankshaft journal. As a resul
... [Read Article]
