Posted by WayneB on September 18, 2013 at 06:16:08 from (132.159.85.146):
In Reply to: Detroit 2-71 in HD5 posted by mokicker on September 18, 2013 at 05:59:38:
Be prepared to use the rebuild kit. Its most likely the o-ring a the top around one or both liners. There is an o-ring at top that keeps coolant out of the airbox, and one at the bottom which keeps oil out to the airbox. If it has been ran without coolant or with low coolant, the heat without coolant present distorts and flattens the o-ring. The headgasket is a fire-ring for the most part. These things have no intake valves just ports in the liner center that allow the blower to fill the piston for upward movement and compression. Its scary how simple they are. You can do the field rebuild without pulling the block. Wayne
Today's Featured Article - It Can't Be Done! - A Tractor Story - by Neil Campbell. I'll never forget the time back when I was a boy baling hay on our Farm in Big Rapid, Michigan. The most memorable event that took place was a trip up the steepest incline on the farm pulling an old New-Idea baler with a pony-motor for power and a haywagon. I had just talked my Dad into buying an old John Deere B with 6-speeds ahead and I was real proud of it, except it was a little smaller than the Case tractor that we normally
... [Read Article]
Latest Ad:
Rebuilt Injection pump for J D 1010. Call or text for pictures or more imformation.free shipping.U.S. No core charge
[More Ads]
