Wayne, your advice is right on 99.9 per cent of the time, but I have to disagree with you this time. The center bolt in the recoil spring is used to hold the spring to a certain length, specified by Cat. Don't back it off after you install it in the track frame. The spring isn't used to put tension on the track, the track adjuster is. It will compress if you get something stuck between the track and the sprocket, for instance, but normally it just sits there. I do agree with your advice about getting a new spring, though. If its available and within the budget.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
