A credible machine shop would know that straightening a cylinder ram takes time. It can only be moved a few thousands at a time and held in that position, sometimes for up to twelve hours depending on the diameter, before moving it further. Back in the 60"s and 70"s I had the opportunity to have worked in a shop that repaired everything except the crack of dawn, and we straightened a lot of hydraulic cylinder rams. Big ones, small ones, short and long. We did some that local heavy duty shops had tried and failed. It just takes time.
Never had an issue with piston retainment that I can recall.
A point of interest: when I left the business our shop rate was $12.50 per hour and no fancy add on"s like "shop supplies" either.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
