Give the guys at SHP a call. Granted they are in SC, but even with shipping I can't see nearly $1000 in a new rod.
That said, if there are still a few good threads in the rod why not have them chamfer the end of the rod around the hole, and then install a stud into the threaded hole. With the chamfer there would then be room to put a good weld bead around the stud to insure it stays in place. Many rods are initially turned with a male thread on the end -vs- using a bolt so it's a well proven design. They may, or may not need to countersink the piston to make room for the nut, but with the stud both threaded (even a little bit) and welded into the rod, I don't think it would ever gove you anymore problems...if it can be done that way.
Today's Featured Article - Fire in the Field A hay fire is no laughing matter-well, maybe one was! And a good life-lesson, too. Following World War II many farm boys returned home both older and wiser. One such man was my employer the summer I was sixteen. He was a farmer by birth and a farmer by choice, and like many returning soldiers, he was our silent hero: without medals or decorations, but with a certain ability to survive. It was on his farm that I learned to use the combination hand clutch and brake on a John D
... [Read Article]
