Have to disagree that properly torqued bolts can't come loose. Some applications call for loctite no matter how tight you put them. Sprocket bolts on high performance motorcycles are one example. Some guys use the red loctite on them. Have seen many a broken hub from the bolts coming loose without loctite. I don't know if this cylinder has ever been apart for new seals but if it was may explain the bolt pulling out or coming loose. I have thought about using the next larger size bolt but I'm not sure what size the original bolt is. It's got to be pretty big for a 4" bore cylinder though. The stick on a backhoe has nothing to stop it except the cylinder piston. There was no o-ring on the bolt and if it was just a tad loose could cause enough oil to leak that it creeped.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
