I would get the rod straightened first. A shop that knows what they are doing will not damage the shaft. Then bore out the end for the next size larger bolt. then tap out cut the new threads in the lathe. Boring will give you a much straighter hole and better size control than a drill. Bore out piston to fit new bolt. Get an L9 or similar high strength bolt, use fine threads. The bolt will be much stronger than the shaft so the thread length should be a least 1 1/2 times the bolt diameter. Be sure to torque the bolt to manufactures spec. Properly torqued bolts don't come lose! Under torqued ones do! Lock tight is ok but is not substitute for torque!
Today's Featured Article - Fire in the Field A hay fire is no laughing matter-well, maybe one was! And a good life-lesson, too. Following World War II many farm boys returned home both older and wiser. One such man was my employer the summer I was sixteen. He was a farmer by birth and a farmer by choice, and like many returning soldiers, he was our silent hero: without medals or decorations, but with a certain ability to survive. It was on his farm that I learned to use the combination hand clutch and brake on a John D
... [Read Article]
