The return fitting you removed is the housing pressure control fitting. Removing it will help engine run better IF it is plugged with small bits of broke retainer ring. I like to test by letting fuel leak out at the timing cover for a quick check. Have even loaded tractors on the trailer this way that would die, then haul them to the shop. It may run OK for awhile with it out, but you will have much more damage later if pump needs repair and doesn't get it.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
