Auction
Crawlers, Dozers, Loaders & Backhoes Discussion Board
Re: 977 traxcavator
Posted by AJ. on June 08, 2013 at 02:53:25 from (92.4.137.180):
In Reply to: 977 traxcavator posted by Lee Olson on June 07, 2013 at 19:36:55:
Been a side valve the valves can hang up esp if its been sitting for a long time,test the compression,remove the spark plugs and block the plug hole with your thumb and turn the pony over,you will feel the pressure if it's got compression,if it has see the plug leads are good and have a spark,clean and set the plugs and try again,if you cant feel the compression a valve is probably stuck.
Good luck
AJ
Today's Featured Article - Recollections of a John Deere GP - by Charlie Cook. I grew up on my dad's 280 acre general farm in Western Michigan. Dad's only tractor when I was very young was the old GP. My first recollection of this tractor was when dad allowed my brother and myself to ride on the tractor with him driving. One of us would sit on the left fender (away from the clutch) and other would sit on the gas tank and hold onto the crankcase breather pipe. ... [Read Article]
Latest Ad: Super WD9. [More Ads]
