If the journal on the crank is OK then there's no reason you can't replace the parts with the engine in the frame. If the journal is going to have to be ground to repair it, then by default they all will. In that case the engine will need to come out. While it's out, think about it, something caused the rod bearing to spin, be it low oil pressure, trash in the system causing a blockage to that bearing, etc, etc. Because your already having all of the rod journals ground your going to have new bearings in all of those spots, and while the crank is being ground why not have the mains checked too, and on, and on. Basically one part of the repair begs for the other, whch begs to go one step further to do it right, and on, and on. In other words you might as well plan to go ahead and do a full rebuild while you've got the engine out and torn down, just to be safe. Personally I've seen too many people decide to 'cheap out' and not do it and come to regret it later....
Today's Featured Article - Fire in the Field A hay fire is no laughing matter-well, maybe one was! And a good life-lesson, too. Following World War II many farm boys returned home both older and wiser. One such man was my employer the summer I was sixteen. He was a farmer by birth and a farmer by choice, and like many returning soldiers, he was our silent hero: without medals or decorations, but with a certain ability to survive. It was on his farm that I learned to use the combination hand clutch and brake on a John D
... [Read Article]
