Auction
Crawlers, Dozers, Loaders & Backhoes Discussion Board
Re: Cat O-rings for oil cooler?
Posted by NCWayne on May 05, 2013 at 19:39:51 from (173.188.169.54):
In Reply to: Cat O-rings for oil cooler? posted by Stick welding on May 04, 2013 at 18:46:15:
Usually the brown rings are viton, as others have stated. As far as using a standard buna-N in it's place let me say it like this. I have seen buna-n rings used in the oil cooler lines many times over the years with no leaks. I also had a truck with a 3406 brought to me awhile back with a leak from one of the oil cooler houing connections. When I pulled it apart I found one viton ring and another buna-n ring. The viton ring was soft and dry, the buna-n ring was hardened and leaking. In the end the viton will definately handle higher temps and last longer in that application, but the buna-n can, and often will seal just as good, for just as long....or not....Basically it's nothing more than a gamble to go that route.
Today's Featured Article - It's Alright Where It Is! - by Anthony West. I have a tale of a different kind to tell. Whilst rooting in the hedge bottoms this week I had cause to visit Chapel lane Farm, the home of an eccentric gentleman by the name of Austin Kendall. I had heard rumours that an old Case Model C was languishing away in the back of one of the outbuildings there. So off I went in search of what would turn out to be a very rare and unusual tractor. Mr Kendall is an excitable chap to say the least. He is amongst the last of a dying breed of farmer who ... [Read Article]
Latest Ad: Super WD9. [More Ads]
