The engine will not run on ether alone,the most likely thing thats wrong is the fuel metering valve in the injector pump is stuck in the stop position,try bleeding the pipes first,loosen each injector pipe at the injectors a few turns,on full throttle crank the engine over on the starter,there should be a spurt of fuel from each pipe union,if it does spurt the fuel out tighten up the nuts and the engine will probably start,if there is no spurt the top cover of the pump needs to be taken off and the metering valve moved to the run position,the valve will stick in the stop position if when the engine was stopped it was left there,there are two pipes attached to each injector,the ones you need to loosen are the biggest of the two that the bottom ends are attached the pump.
Today's Featured Article - It Can't Be Done! - A Tractor Story - by Neil Campbell. I'll never forget the time back when I was a boy baling hay on our Farm in Big Rapid, Michigan. The most memorable event that took place was a trip up the steepest incline on the farm pulling an old New-Idea baler with a pony-motor for power and a haywagon. I had just talked my Dad into buying an old John Deere B with 6-speeds ahead and I was real proud of it, except it was a little smaller than the Case tractor that we normally
... [Read Article]
Latest Ad:
Rebuilt Injection pump for J D 1010. Call or text for pictures or more imformation.free shipping.U.S. No core charge
[More Ads]
