Posted by Dennis K (WA) on April 07, 2013 at 17:27:50 from (24.21.78.195):
In Reply to: International T-6 posted by RandyM on April 07, 2013 at 15:46:59:
Welcome Randy, I also have a T6 but the narrow row crop version.
The front of the tractor is supported by a heavy leaf spring that crosses over from track frame to track frame under the main frame and hinges in the middle so the tracks will oscillate individually. It is near the rear of the engine and rests on the track frames on a button right behind the front idlers. It is possible the spring is broken, you'll just need to inspect it. You may need to remove the belly pan to see it all.
With the heavy blade and nose guard, it may be normal.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
