Thanks, I think you might do well to remove the pump Tim. It would be easier to drill the broken manifold studs. To remove the pump take the TDC plug out of the flywheel housing and the 9/16"hex plug from the odd shaped housing rear of the plate on the pump. Rotate the engine untill the shank of a new 1/4" drill bit will go down the hole in the pump and drop into the slot in the camshaft. Check the hole in the flywheel is inline with the hole in the housing and a 3/8"NC bolt will thread into the flywheel. You are now timed up. Take off front cover and pull gear off tapered shaft. When installing pump amke sure bolt will go into flywheel and the #1 valves are both loose. Turn pump shaft untill drill drops into slot, mount pump and install gear.To install gear torque bolt to 100 Lb Ft. You need a special socket to take nut off of pumping element, fuel shop might be best way to go. Later Bob
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too.
... [Read Article]
