Posted by Stick welding on February 27, 2013 at 22:47:34 from (96.53.210.246):
In Reply to: Mitsubishi DB2G posted by CBBC on February 27, 2013 at 19:56:43:
Are the sprockets worn down and/or broken off or they still have 3/16" on the tips? If the latter, they still have a little life left. When they get pointed and start breaking the tips off, they are done. I use universal tractor fluid in my Cat for the hydraulics. It says on the pail it can be used for hyd. systems. I use Esso Cat spec. oil in the trans. In my MF tractor I use the MF Perma-tran and find it works the best. The pyramid pads are for working in the muck or rice fields I think. They're self cleaning but aren't the best for working on drier ground. The wider the pads, the harder it is on the undercarriage.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
