I checked everything possible out and everything checks out. I took the panal out and on the back side it has a burnt spot so that tells me something went wrong with it. I have made the machine run by disconnecting wires to the panal and jumping the start interlock relay to get it going. I put power to the pedal locks to release them. I have checked it all. Even found what might have shorted it out. The wires to the hyd charge pressure sensor were broken and I believe they shorted out. The one thing I am having trouble with is what i believe to be a overheat shutdown harnass that connects to the fuel pump. IT gets power from the pump goes to the temp sensor then goes to a solenoid on the bottom of the pump and then goes back to the pump for ground. This cuses a fues to blow every time. It does not however explain why this machine will not function or start. The seat belt circuits and seat buttons are fine. It all leads to the panal not putting power out where it needs to go.
Today's Featured Article - Madison's County - by Anthony West. Philip Madison has been a good friend of mine for quite some time. He has patiently suffered my incessant chit chat on the subject of tractors for longer than I care to remember, and on many occasions he has put himself out, dropped what ever it was he was doing, to come and lend a hand cranking handles, or loading a find onto a trailer. Although he himself has never actually owned or restored a tractor, he was always enthusiastic and always around helping with other peoples projects.
... [Read Article]
