First, I would drain out ALL of the antifreeze, then put the head back on and VERY THOROUGHLY flush the cooling system with fresh water (you want to remove ALL traces of antifreeze). then fill the cooling system about half way with fresh water & then add 1 Quart of Sodium Silicate (aka: "Water Glass"), and then fill the cooling system up with fresh water. Start the engine and let it idle for about 1 hour while closely watching your temp. gauge (you don't want it to overheat). Check your coolant level & check to see if your leak has stopped, if the leak hasn't stopped keep idling the engine a while longer. - I have used Sodium Silicate to repair all kinds of cooling system leaks: cracked heads, radiator leaks, heater coil leaks, and cracked blocks. In FACT I sealed a cracked block that had a crack big enough that you could drop a kitchen match through the crack, it didn't seal right away but it DID seal.
IMPORTANT: Do NOT under ANY circumstances put Sodium Silicate into a cooling system that has antifreeze in it! The Sodium Silicate will turn the antifreeze into a thick gelatinous mass that will completely plug up your cooling system.
Today's Featured Article - Madison's County - by Anthony West. Philip Madison has been a good friend of mine for quite some time. He has patiently suffered my incessant chit chat on the subject of tractors for longer than I care to remember, and on many occasions he has put himself out, dropped what ever it was he was doing, to come and lend a hand cranking handles, or loading a find onto a trailer. Although he himself has never actually owned or restored a tractor, he was always enthusiastic and always around helping with other peoples projects.
... [Read Article]
