Crawlers, Dozers, Loaders & Backhoes Discussion Board
Re: jd 310 battery cables/battery
Posted by ben brown on January 22, 2013 at 16:59:58 from (184.63.225.47):
In Reply to: jd 310 battery cables/battery posted by bill h on January 21, 2013 at 14:54:20:
on jdparts if once you put the idem in shoping cart if you click on the part number it open a new window and most time give you specks. neg cable
Specification
Weight 2.31 LBS 1.05 Kg
Length 16.339 IN
Metric Wire Size (mm2) 62.000
Wire_Coverings 1-OR-9
Color BLACK
Left Terminal Code / Angle 100/00
Right Terminal Code / Angle 100/00
Finish B
Note B
English Metric
Specification
Weight 6.02 LBS 2.73 Kg
Length 85.433 IN
Length 17.323 IN
Color RED
Left Terminal Code / Angle 006/60
Center Terminal Code / Angle 200/90
Right Terminal Code / Angle 200/00
Finish B
Note A
pos cable
Part Diagram
Part Diagram
This post was edited by ben brown at 17:03:24 01/22/13.
Latest Ad: Super WD9. [More Ads]
