Posted by AJ. on January 08, 2013 at 08:57:31 from (92.4.145.75):
In Reply to: timming still not right posted by bobs old iron on January 06, 2013 at 22:26:07:
I believe those machines had a Hercules flat head engine,if that's what you got the firing order is 1-2-4-3, #1 is at the front end, remove the four spark plugs, you now need to remove the mag cap, turn the engine in its normal direction of rotation by hand and note the direction the rotor turns, now block the #1 plug hole with your thumb and turn the engine till you feel the compression against your thumb,the engine is coming up on compression stroke of #1 cylinder,the flywheel timing mark should come into view in the timing hole on the bell housing,set the mark to the pointer, now check where the rotor is pointing to in the mag cap,that lead should go to #1 cylinder. the next lead in the direction the rotor turns goes to #2 cylinder, then the next to #4 and the last to #3.with the points clean and gapped correctly put the cap back on,put in the plugs and try for a start.
Today's Featured Article - Madison's County - by Anthony West. Philip Madison has been a good friend of mine for quite some time. He has patiently suffered my incessant chit chat on the subject of tractors for longer than I care to remember, and on many occasions he has put himself out, dropped what ever it was he was doing, to come and lend a hand cranking handles, or loading a find onto a trailer. Although he himself has never actually owned or restored a tractor, he was always enthusiastic and always around helping with other peoples projects.
... [Read Article]
