Posted by Roy Suomi on December 23, 2012 at 07:27:34 from (76.190.196.2):
In Reply to: john deere 410 posted by curtis berkley on December 18, 2012 at 15:31:25:
Nope.. Not power shift.. Just Clutchpack.. If it's a straight 410, you pull the plate that the shifters come up thru.. Look down there and you might find a piece of metal missing on the end of one of the shift shafts that push or pull the shift forks..It's very common.. I just fish out the pieces and fabricate another piece , then weld it to the shift shaft.. Outerwise the correct repair is to split the tractor behind the reverser and change out the shift shaft..Quite a little undertaking if you don't have to..I've done this about half a dozen times with good results..With that piece missing , you can't move the shaft to get it into low range.There are "interlocks" on those shafts so it can't do 2 different gears at the same time..
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
