Posted by Dennis K (WA) on December 03, 2012 at 11:31:06 from (24.21.78.195):
In Reply to: Drott Skidloader posted by tpmx on December 02, 2012 at 11:47:03:
tpmx, What I am about to write is somewhat generic because I'm not sure what your valve has but here goes.
The spring and poppet you talk about in the spool may be what is called a regeneration valve and the purpose is to refill the upper end of the lift cylinders when the boom is dropped rapidly. Not sure how it may apply to your problem.
Many hyd valves have what is referred to as port reliefs or circuit reliefs for each operation. It would be common for hoist up to have one to protect the cyls and boom if when up something fell from above or a bank would cave in. If this relief was bad or had a broken spring it would cause your problem and would not effect the down operation.
Another thing, is it possible that the linkage is worn to the point that the lever is hitting the frame work before the spool is stroked enough? I have seen this before.
I doubt cylinders if you have down pressure but they could be tested for bypassing.
As I said these are generic comments and may not apply to your specific valve.
Today's Featured Article - It Can't Be Done! - A Tractor Story - by Neil Campbell. I'll never forget the time back when I was a boy baling hay on our Farm in Big Rapid, Michigan. The most memorable event that took place was a trip up the steepest incline on the farm pulling an old New-Idea baler with a pony-motor for power and a haywagon. I had just talked my Dad into buying an old John Deere B with 6-speeds ahead and I was real proud of it, except it was a little smaller than the Case tractor that we normally
... [Read Article]
Latest Ad:
Rebuilt Injection pump for J D 1010. Call or text for pictures or more imformation.free shipping.U.S. No core charge
[More Ads]
