Posted by AJ. on December 01, 2012 at 17:25:54 from (92.4.138.49):
In Reply to: hard to start old D6 posted by milkermp on November 30, 2012 at 01:43:46:
The machine would have a pony motor originally but has been converted,it should have a 24 volt starting system fitted which would include glow plugs and 24v charging,the idea of the decompression was for to engage the pony motor and build up fuel and oil pressure,you would then with the throttle in the stop position go to full compression,spin over on full compression so the air in the cylinders gets hot, give it throttle and the engine would start,the use of ether has probably caused the ring gaps to widen resulting in poor compression and hard starting.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
