Posted by DGH on November 08, 2012 at 20:11:32 from (72.25.192.4):
In Reply to: Re: Hough transmission posted by Bill in IL on November 08, 2012 at 13:37:30:
If your convert er temp goes up when hill climbi ng and returns to normal when not, then I would think it is getting the proper oil supply. If it were hot all the time that would be different. The converter must be full of oil all the time, if it was straved of oil and not full it would soon destroy itself. I would go back to the transmission control. There should be ports for checking the pressure on each clutch pack. Put gauges on all of them and see that they go to full pressure when in use and turn to zero when not. You may have a leak that allows partial pressue to a clutch when it should not have any causing an internal drag in the transmission. That is the only thing I can think of that would cause your strange problem.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
