stoughtonfarmboy
First year using a Kuhn GMD400 disc mower. Tractor is a JD 5065E. Works fine.
But, when I hook it onto the 3-point hitch it is offset to the right. I was able to adjust the stabilizers. The left side is forward as far as it goes. The right side is extended about 6 inches. I pinned them so it does not sway. This adjustment makes the PTO shaft almost straight.
Thoughts?
Looks as if the pins for the lower arms might be able to be moved.
Picture does not show the offset, but shows it in use.
Thanks
Ken
Thoughts?
Thanks
Ken
