Kuhn discmower
I will be using a used Kuhn GMD400 discmower for hay in 2022. I have a manual, changed the oil and put on new blades. First time for me. A little unclear on use of the check chain. Tractor is a John Deere 5065E.
I used a NH Haybine for several years. Finally broke and bent enough to give it up. It had a nice feature: 3 different sized spacers so I could set the cutter height where I wanted it. Easy to raise mower then set down and forget it. I mow 6 small 2 - 4 acre fields. Mostly grass with a little clover or alfalfa, smooth and no rocks. Southern Wisconsin horse hay for a couple neighbors.
My test drive before I put Kuhn in shed seemed as if I had to lower cutters and eyeball if horizontal and how far off the ground.
Suggestions welcomed.
Ken
Makes more sense. I read the manual again. Also the tractor manual. I only use the 3-point for counterweight with heavy load in bucket or with snowplow attached.
Ken
Picture of snowplow just for fun.
Send me an e-mail with your phone number and I will send you a picture of how to adjust the check chain.
I tried to send an email a week or so ago. I updated the email in my profile. It was way outdated. Just added my email to this reply.
Will see if this works.
Thanks
Ken
Chain was designed to limit how far down tractor 3pt can go. Attach loose end of chain at desired draft link height to 3pt centerlink attaching bracket on your tractor.
