ChampagneNBeer
Hi All,
Busted up an old section of field today, think it came out pretty good (see attached image).
My plan was hit it one more time with the disc then to let it sit, then tandem disc it when weedies sprout, then drill seed.
But I also have a spring tooth drag, one of those drags but the tines are like chopsticks, as well as other implements.
Based on the photo, should I hit it again with the disc now, use something else now, or wait until weedies come up and then hit it (if wait, when time, hit it with what implement?).
BTW - it went from sod to what you see with just a couple passes of that IH offset disc
Thanks
Thanks
