Robert (ID)
Spent the morning setting out a pump and sprinkler pipe on a pasture. Then started pump and pipe on an established hay field. It was after 10:30 when I finally got to the tractor and plow (JD 4650 and 4200 4-18). Went and plowed out 30 acres of winter killed hay and 2 field adjacent food plots. While plowing out the winter kill Sod, I came to a couple conclusions, 1st the transmission on in the 4650 is fine. When 4-18's will bring the front end of a MFWD 4650 off the ground 18" the trans isn't slipping. 2nd I think I better start looking for a weight bracket and hang some more weight on the front..
The good news is both pumps ran there full sets.
I got some much needed ground work done and much needed "seat time therapy"
In this time of Confusion in the world " FARM ON"
