ridgeandvalley
Am I crazy to consider picking up an old sickle mower for cutting hay? I've been using a NH 469 haybine for a few years now, and had a breakdown at the end of last year, just as I was getting pretty handy with it. I'm going to dig into it and see if its fixable, but if it isn't, I'm looking for a backup plan.
I've only got a couple of 4 or 5 acre hay fields and its grassy hay. It's kind of silly to invest a lot into fancy equipment for the small amount of hay I make. The only reason I do it myself instead of having somebody do it for me is that I can do it on my schedule and not wait until someone else has time. I've been in that situation before, and it was frustrating to miss good windows of opportunity because I was too small to bother with. Since I've started doing it myself, I've found it enjoyable as well. The feeling of satisfaction when putting it up and when feeding it through the winter is just different when you do it yourself.
So, if I could pick up an old sickle mower for a few hundred instead of looking for an older haybine which is probably going to cost 3 - 4 times as much, would it get the job done efficiently on small fields of grassy hay? Or, would the lack of conditioning rolls really slow down the drying process? I've also heard people complain about clogs, etc... with a sickle mower.
Any other pros and cons I should know before I seriously consider looking at this as an option? Grass is starting green up and I'm starting to think about hay.
Thanks in advance for any input.
