9ft haybine (sickle machine) would be a good match. If wanting a disc mower type machine, 7ft would be about all you could handle.
(quoted from post at 15:11:56 03/08/20) I pulled a NH460 12 footer behind my Oliver 77 and it played with it. The 77 as per the Neb. test is 38HP
I thought NH 460 Haybine only came in 9' model. I utilize a 64 pto hp tractor to pull a 9' disc cutter.
We pull a 1219 JD mower conditioner. A 50 engine hp. JD COMPACT tractor is plenty. Oh it is 9ft.
