toolgarage
I just bought a '79 Ford 5600 that has four rear hydraulic connections (2 control valves). I just found a 3-point backhoe attachment local to me that works from a single pair of hydraulic connections.
My question is - how do you open the flow/bypass the valve on the tractor to allow fluid to flow to the control valves - unimpeded - on the backhoe?
I'm guessing/hoping I'm missing something simple and this will just work, but I wanted to check with the group before committing to a purchase that will require modifications to the tractor to make it function.
Thanks,
Tim
Thanks,
Tim
