olgentdc
if i use L D 4 , on no till ground for corn ,,how long after spraying must i wait before planting corn, ? some guys around
here plant the next day after spraying,. i have a distant field that i will spray ,then broadcast fertilizer and urea
hopefully before a rain,,. then plant as soon as it is dry enuf ,///. or if it dont rain , i may cut disc the ground to cover
the fertilizer.. but that is a waste of L D 4,. i usually at the least disc and plant ,. most times chizel ,
