No-till corn
Fred2
You guys that have gone to no-till how often do you deep rip your ground and what type of soil do you have? I am talking about corn ground
Brother has been no-till 30 plus years, all soil types. Has not ever deep ripped anything. His best results have been using cover crops. Google Ray Archuletta to know more, makes sense when he explains it..
The deepest mine had had is the anhydrous tool bar that went thru Saturday.(Over twenty years)I forgot about CRP,its been thirty years.
32 seasons. No deep till, or till for that matter. Silt loam soils. We do have alfalfa in the rotation, which has deep (10 foot) tap roots.
Have no tilled corn for at least 30 years. I do a corn-soybean rotation. Try to deep rip as much bean stubble in the fall as possible. I use a five shank ripper pulled by a MX245. Run it as deep as possible at 5 mph. May give cover crops a try. Have a neighbor who does cover crops in the late summer using an airplane. He is very satisfied and has quit deep tillage.
In my neck of the woods, the only time no till corn ground sees anything, is when someone puts on gas fertilizer and knifes it in. Typically a corn soybean rotation. Some add wheat to the rotation.
You use a ripper made to use in no till ground.It works deep and leaves trash undisturbed on top.
You use a ripper made to use in no till ground, It works up the hard pan & leaves the trash on the top undisturbed.
Don't own a ripper, silty clay loams and silt loams. Usually 2- 4 years in corn/ beans, total no til unless we get some ruts. Then rotate to hay after beans for 6 years or so. I've never run anything deeper than a chisel plow set at 4 inches to straighten up after a wet silage chopping.
I am guessing all of you guys or under the control of Monsanto or a branch of it? So sad what they are doing to America. We used to be able to save our seeds and replant in the spring which brought prices way down. Now if you do that in just a few of the cross-pollinated seeds from your neighbor's corn crop then you will be fighting for your farm with Monsanto in court. I think it's time for all the farmers to rise up against this Beast. It's doing nothing but putting Farmers on a pesticide treadmill and just Making
Monsanto even richer.
Ummm, so who's treadmill are you on??? I plant a lot of conventional corn with no traits. And I no till all of it. Because of that, my soil is healthier- building organic matter, more worms, bacteria, etc.I
spend way less on fuel, labor, machinery, you name it. Most importantly, no till reduces soil erosion dramatically, so my soil is around for my kids, and hopefully my grandkids. 2016 was our 31st season on
some fields, and our yields were the best ever.
If you think we all work for Monsanto because we no till, think again. We do it because we think it is best for a pocketbook and the environment. You'd be hard pressed to do either doing things "the old
way."
