Posted a similar thread on another forum, but thought I'd post it here too....
Sent off some soil samples on some fields I'm starting to reclaim and they are in bad shape.
I understand staging N - nitrogen, but what about P - phosphorus and K - Pot Ash? Stage it or apply the mother load all at once/now? Planting Teff in these fields next spring, Timothy the following fall. Don't anticipate plowing - except one field (possibly), but doing roundup and no till planting.
Here is one field's test results:
I am to apply the following:
N = 90
P = 110
K = 185
PH = 5.7
Lime = 1.25 tons per acre.
With other fields, I have divided similar test results in half for application, except lime, where I limit it to 1 ton per acre per application for no till.
All of my test results are somewhat similar - in magnitude.
Question is - this fall do I dump 110 lbs per acre of P and 185 lbs per acre of K on no till at once or divide up the application like I do lime and N? Will the P and K stay put and soak into the ground or wash away from rain? Land is pretty much flat on these fields, but a few rolling places too. Creek borders one field.
What are some typical N, P and K numbers you see off of your grass hay fields?
Any tips are much appreciated.
Thanks!
Bill
N = 90
P = 110
K = 185
PH = 5.7
Thanks!
Bill
