This message is a reply to an archived post.
I noticed this forum with respect to splicing wire fencing ideas. From what I have found, crimp splices are only a temporary fix which isn't good if you are protecting your investment and tying wire fencing can be difficult especially with high tensile or old/brittle wire that will break. Check out this link to Ranchmate ( http://www.ranchmate.com ). If the DOT specifies a "Western Union Splice" that is a method, than Ranchmate' Twist Splices would be the easiest and strongest splice available with no tools needed. Average retail cost per pair of inline splices is only around $1.99 each. These splices are a preformed western union splice that you would use and are the exact same products (Shrunk down) as what the power and energy companies use to splice/repair power lines and cables. Products like these are significantly better than a method that might be incorrectly applied.. Let me know your thoughts. Thanks.
Untitled URL Link
Untitled URL Link
