Wire Fencing Splice
Ranchmate
New User
This message is a reply to an archived post.
I noticed this forum with respect to splicing wire fencing ideas. From what I have found, crimp splices are only a temporary fix which isn't good if you are protecting your investment and tying wire fencing can be difficult especially with high tensile or old/brittle wire that will break. Check out this link to Ranchmate ( http://www.ranchmate.com ). If the DOT specifies a "Western Union Splice" that is a method, than Ranchmate' Twist Splices would be the easiest and strongest splice available with no tools needed. Average retail cost per pair of inline splices is only around $1.99 each. These splices are a preformed western union splice that you would use and are the exact same products (Shrunk down) as what the power and energy companies use to splice/repair power lines and cables. Products like these are significantly better than a method that might be incorrectly applied.. Let me know your thoughts. Thanks.
Untitled URL Link
I disagree, crimp splices are very permanent. Besides, this post sounds like a cleaverly placed add.
Certainly not a placed add. I just have never heard anything good about splices. I've always thought of them as a band aid solution only. Expansion and contraction alone takes a toll on splices.
Certainly no advertisement. At the end of the day a western union splice is open to interpretation as to how to correctly utilize. A Twistsplice is a preformed version of a western union splice to guarantee a stronger and safer splice. Appreciate the the reply..
Did you ever fly in a small aeroplane?
Did you survive?
Did you realise that the control cables were most likely held together with Nicopress swages?
http://www.aircraftspruce.com/catalog/appages/nicopress.php
Which work fine on the line wires in fencing if you follow directions on swage and the go-no go gauge
Nicopresses look to be much more heavy duty but hey if it works for you, great. I've met numerous folks that can't stand crimps because they simply failed.
I guess comparing an airplane accessory would be the same as the Twist Splices being compared to the splices used on Power lines. Once those snap the Lineman uses a larger version of a twistsplice/(helical design to repair) and the stress, tension and weathering on power lines are extreme...
Not an ad? Lol.
Your username is ranchmate you schill ranchmate and provide a link to ranchmate.
Surprised this thread is still active.
