Revamping a splitter bought at auction
Splitter was set up to run with tractor wet line...I'll be using a 2N with gear pump on pto
Question!
Am I correct to think that all I need is lengeth of 4" X 3/16 wall pipe to weld pipe fittings onto, to use as a surge/supply tank? This will make the system self contained, to use with any pto .
The splitter has a 4X24 cylinder, and should need a 24" section of pipe as a reserve tank, once the system has purged the air out........tell me if I'm on the right track
Oh, the splitter has had little use and bought it for $200!
Question!
