Eric in IL
One of the local Coop's has switched to spraying on a 30 degree angle instead of following a field edge or following the planted rows.
Creating point rows for yourself is normally not a popular method of farming unless there is some definate advantage to doing so.
Who knows their reasoning as I am coming up empty on a good reason ??
The fields I'm seeing this pattern used on are drilled beans.
