Truck1Drew
New User
So I have been trying to plant a dove field since late April with no luck. I'be tried 2 times to plant 7 acres of sunflowers and two acres of corn with no luck. I own some land in central Alabama which for the past several years I've leased to a hunting club. Every year they have beautiful sunflower crops for dove fields. This year they did not renew their lease so I decided to give the dove field a try. I chisel plowed, disked, and drug the same plots they used last year. At the time the only planter I had was a ford 309 no till planter which I used on one field. Then I acquired a Cole planter to go on my farmall 140. I did not use the $200 roundup ready seed and went with normal sunflower seed. So I decided to go with the Cole planter so I could plow for weeds with the 140. About 10 days went by and the only plants I had come up were the ones I did with the no till planter. I had decided that the Cole did not cover up the seed well enough due to the ground being too hard. Try #2-- the 2nd time I tried to plant I used a middle busted and busted my rows deep then used a set of sweeps on the 140 to fill in my rows and then re planted with Cole planter on the 140. The planter covered up the seed very nice which I planted 1" deep. Still.... No sunflowers. I have about 5% of the whole plot coming up. I talked with my local extension officer and he advised to replant again. The weather here has been warm during the day but would drop into the 50s at night up until this past week. It's been warm all day and night. My question to ya'll is what should I do as far as ground prep/planting to have some luck this time? I have just about every kind of plow and disc available. However all I have to plant is the cole planter and the no till. The fields have already been fertilized. The no till is set up on 38 1/2 inch rows. I did a little experiment yesterday and I think I could plow between those rows with my farmall which is set up on 5' center. What would y'all do?????? I'm bound and determined to make this work!! I have a kubota m7060 and a farmall 140 to do all the work with.
