Remedy Ultra Herbicide
Rob Mo.
The neighbor has asked me to mix up some weed killer for him. After reading the booklet that came with the chemical, it never tells you a simple formula on how to mix it. The spray is
Remedy Ultra specialty herbicide. I only need about 2 gallons mixed. Just not sure what water/chemical/fuel oil ration to use. If anyone has a basic rule that you use, please share.
Farm chemicals are not mixed according to xxx amount of chem per gallon water...they are mixed according to xxx amount of chem per acre of coverage. How are you going to control application rate? That"s why "homeowner" Roundup is sold in a weak formulation....because homeowners just "shlook" it on their property.
