I have a VERMEER 605D question? Please help
RoboFarmer
New User
Ive got this 605 D Im planning on running this Summer.I put in some new bearings and the belts are good.It runs fine,but the belts dont turn.Do they tighten up and begin to turn when some hay goes into it? Thanks for any help
Probably need to have the belts shortened. I would get a dealer to do it if possible. If you do it, leave one belt on the baler to use as a pattern for threading the repaired belts in, at the last repair the single belt left.
KEH
My F will be that way, most especially when it has sat all winter, the belts do t run until you feed into it a bit.....
Paul
Thanks Paul,I took off a belt and measured 442 inches with plenty of slack.Max length is 450 inches,so we know they arent too long as previously mentioned
