WHats yalls fall and spring tractor setups?
Spring- 4960 cultivating, 4450 discing,rowplanting, 4430 dean drill, 3020 drain plow.
Fall- 4960 graincart and boll buggy, 4450 mowing stalks, 4430 module builder, 3020 no job. :p
8430 disking and cultivating.
4440 spraying and pulling no till 750 drill
7800 pulling the no till 1760 12 row vacuum planter.
4440 on the moco.
4020 square baling and raking.
7800 and 4440 round baling.
8430 on the grain cart during harvest.
7800 or 4440 on the batwing mower when needed.
Farmall M grinds feed.
Farmall A runs bale elevator and auger.
I had another 4440 without duals and I stupidly sold it. I have to be pretty good at swapping things
during hay season without it. I'll find another someday.
Tillage is the 400D and 450 gas plowing and disking. The 340 does the planting and cultivating.
Fall I will use the 340 on the McCormick 80 for my small fields of beans and the Gleaner AII for the corn and larger bean fields. The 400D or 450 will run wagons unless I have a grain truck by then.
Spring tillage....fert. spreading....planting. IH 1456 and IH 1466. Making hay...cutting...raking..tedding..baling. Case 730 CK and IH SM.
John
Plow Ford 7700, disc & cultimulch 3020, grain drill JD A, corn planter MM U, fertilizer MM M5
Haybine 3020, rake Farmall A or MM jet star 3, baler 7700, wagons M5
7610 C/H/A 2wd on round baler. She tends to run a tad warm with a clutch fan if I put her
on the discbine. 7610 C/H/A 4wd and TB 110 canopy on discbines. 5600 on tedder. 7600 on bar
rake, 7610 low profile on wheel rake. All Ford/New Holland. Skid loaders, pair of 1845C's
(Case) and a 257B Cat loading rolls on trucks and stacking in barn.
