Pre Emergent and pumkins and squash??
Was gonging to try some Pre Emergent in the squash and pumpkin patch, anybody done this?? Don't know to much about this stuff, will it work??
OK,I'll bite. Is there a "Pre Emerge brand" herbicide or are you just talking about using a herbicide before anything comes up?
here's my story, I use a product called "Parallel" last year on my sweet corn. disked, Sprayed, planted and no weeds life was grand!!I thought it was a "pre-emergent"?? Being you used it before it emerged?? It says herbicide?? I don't know much about this stuff as you can tell. I would like to try a punkin patch this year and I gust figured...Thanks for the help!!
All the information is contained in the labeling. Not necessarily ON the label on the jug,box or bag,but also in any booklet or pamphlet that comes with it. I never heard of the product and don't know if it will kill the crops you want to use it on. You have the advantage by having the labeling in your possession to read.
command ec and i beleive curbit.. stradagy is a jug mix works also . spray on a calm no wind day . drift can be an issue READ THE LABELS
1 pint per a Command
1 pint per a Duall
1 pint per a Trifluralin
Mix the three together and spray right after you plant. Read the labels on the chemicals before hand though. Works best if you get rain within a few days after application.
I'm not saying it will work for you but the combination has worked well for me.
Is dual still labeled for Pumpkins? I know there used to be a "supplemental label", but can't locate it this year.
I have been burning off with Roundup, using Sandea, and hitting between the rows again with RU if any problems pop up.
