Tell us more. Is this for boom spraying in a field? Spot spraying near the pasture fence? I'm using a mix of 24D, roundup, and WEX to burn down crop land. Depending on the rate some fields I wait 14 days, some up to 30 days to plant. In the drive and around buildings I always use a spot sprayer with 24D and glyph really strong so it works better. Forefront has other things in it for carryover and better kill. Some stuff you can't get killed off once it gets too big.
When you're mixing chemicals,put a little of each,preferably the same ratio that it will be in the tank,in a quart jar and make sure they don't have a bad reaction.
Grazon, milestone, Tordon.
Look at the active ingredients in them, and pick the cheapest option. Some of these will soak down and kill trees so spray with caution. Some of these last 2-3 years in the soil keeping broadleaves down, so apply with care.
I assume you only want grasses left.
Paul
