This might seem like a silly post. I have a small yard beside and in front of a barn that hold water on the surface in puddles. Sometimes pretty deep. This ground was once shaped so the water would run off and was usable but I think some heavy tractor ruts and lack of use has spoiled the drainage it had. I first though the ground was saturated but I actually put all new fence and posts and divided it up a bit and restored the fence along the road. the post holes go in 4' deep and the ground was dry under the surface and sometimes would take 1/2 hour before the surface water would fill the holes (to give you an idea of what the dirt is like>
I have A loader with a trip bucket. a rear scraper blade and a box blade. Would I be able to restore good drainage with those tools? (I think I can) but how would I know when to add more top soil to raise an area? should I work it while it's muddy or try and wait for it to be dry? When it's really muddy the tractors sink if you drive over a spot more than once and it's hard to pull anything while it's slipping. I've just never done this before and don;t know what to expect or where to start
