Green corn silage to cured (fermented) ratio
Looking for info on what the weight difference and or volume difference is between green corn silage and fermented corn silage is. Assuming it is harvested at a "good" moisture content. This would be not including spoilage.
Thanks
Upright silos settle but the only real ''loss'' will be through spoilage or wastage if harvested at the proper moisture content for the storage system in use. I switched from bunker to bagging 7 years ago and have very little spoilage.
