TractorLinks.com
Using Your Tractor & Crop Talk
Discussion Board - Re: ALFALFA AFTER ALFALFA
Paul
08-11-2014 06:54:40
It might work, but the odds are against it.
The research on it shows if any alfalfa plants are present, they need to be dead, and then wait 3 months of good growing weather before replanting alfalfa seed. A growing alfalfa plant over a year old is putting out toxins up to 2 feet around it that suppress new alfalfa seedlings.
Most would plant a grass crop in between to use up the N you get for free in the ground, like corn, but technically you could kill the alfalfa after first cutting, then come back in early fall and reseed to alfalfa.
A person can get lucky and have it work out inter seeding or waiting only 2 weeks, but that will be the exception, not the rule. It works just often enough that a friend has had a friend hear of it working so it must be ok right?
If it works, likely your old alfalfa was dormant from a long drought and allowed the toxins to break down, and the old alfalfa was not actively growing to put new toxins in the ground for several months. Then you need to get lucky and have a good rain after you seed to grow the new seeds. All in all a very risky thing to try, with how expensive alfalfa seed is.
Most times he will get the same patchy poor stand he has right now.
Paul
Paul
08-11-2014 07:04:31
 Re: ALFALFA AFTER ALFALFA in reply to Paul, 08-11-2014 06:54:40
Here is a bit more about it:
http://m.hayandforage.com/mag/farming_alfalfa_alfalfa_alfalfa
The keys to making it work are a dry environment, and not having any leaves on the ground.
Works in a very efficient SW dry climate alfalfa operation, doesn't work in a typical wetter climate with less efficient harvesting with leaf loss.....
Paul
