TractorLinks.com
Using Your Tractor & Crop Talk
Discussion Board - Re: Planting Milo ?s
Brendon-KS
07-27-2014 19:48:26
Here in dryland (not irrigated) central Kansas most folks shoot for around 5 lbs/acre, nearly always in 30" rows. This will put the plants about two or three inches apart. Most milo has around 15,000 seeds per pound so the population would be in the 75,000 range. A few guys drill it but not many. Any plate-style or air/vacuum planter will do a good job with the correct setup. I've used a Deere 71 with B27769 plates and Y5055 fillers but there are other combinations that would work too. The plates with cells that fit a single seed should be used with a star knocker so the seeds don't get stuck. The plates that fit several seeds per cell (like the one I use) are used with the regular round wheel knocker. Most milo plates require the use of the proper filler ring since they are usually thinner than corn plates.
