steve in wi
Iam in se wi and only do 35 acres of alfafa grass mix.The last few years i,ve cut with my haybine,9 footer,and then next day run a conditioner over the windrows again. I do this because i have not straight fields mostly curves,so i do end up driving over quite abit.Will a tedder help me out alot more than that conditioner,my rolls are good in the haybine,just need to pick up the hay that was driven on. By using a tedder can i pick up the driven on hay and say a day drying maybe.Do they help out that much. Thanks for the input.I figured larry in neil would be close to my weather area. Steve
